Info PHP - ne pas supprimer
PHP logo
PHP Version 7.1.9
System Linux webm373.240.ha.ovh.net 4.4.67-ovh-vps-grsec-zfs-classid #1 SMP Thu May 11 18:47:35 CEST 2017 x86_64
Build Date Sep 21 2017 10:35:02
Configure Command './configure' '--with-openssl' '--with-mysqli=mysqlnd' '--with-pdo-mysql=mysqlnd' '--prefix=/usr/local/php7.1' '--enable-fpm' '--enable-memcached' '--enable-opcache' '--enable-mongodb' '--enable-redis' '--with-gd' '--enable-intl' '--enable-gd-native-ttf=/usr' '--with-png-dir=/usr' '--enable-wddx' '--with-config-file-path=/usr/local/php7.1/etc' '--enable-sigchild' '--enable-short-tags' '--disable-rpath' '--enable-libgcc' '--with-zlib=/usr' '--enable-bcmath' '--enable-calendar' '--with-curl=/usr' '--with-gdbm=/usr' '--enable-ftp' '--with-gettext=/usr' '--with-imap' '--with-kerberos' '--with-imap-ssl' '--with-mcrypt=/usr' '--with-mhash=/usr' '--with-jpeg-dir=/usr' '--enable-exif' '--enable-sysvsem' '--enable-sysvshm' '--enable-sysvmsg' '--enable-zip' '--enable-inline-optimization' '--enable-soap' '--enable-mbstring' '--enable-mbregex' '--with-gnu-ld' '--with-libxml-dir' '--enable-shared=yes' '--enable-static=yes' '--with-xsl=/usr' '--enable-sockets' '--with-xmlrpc' '--with-iconv' '--with-imagick' '--enable-pdo' '--with-pdo-pgsql=/usr' '--with-xpm-dir=/usr' '--with-pcre-regex' '--with-freetype-dir=/usr' '--with-pspell' '--with-pgsql=/usr' '--with-bz2' '--with-gmp' 'EXTENSION_DIR=/usr/local/php7.1/lib/php-extensions'
Server API FPM/FastCGI
Virtual Directory Support disabled
Configuration File (php.ini) Path /usr/local/php7.1/etc
Loaded Configuration File /images/jessie.i386/usr/local/php7.1/etc/php-fpm.ini
Scan this dir for additional .ini files (none)
Additional .ini files parsed (none)
PHP API 20160303
PHP Extension 20160303
Zend Extension 320160303
Zend Extension Build API320160303,NTS
PHP Extension Build API20160303,NTS
Debug Build no
Thread Safety disabled
Zend Signal Handling enabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
IPv6 Support enabled
DTrace Support disabled
Registered PHP Streams https, ftps, compress.zlib, compress.bzip2, php, file, glob, data, http, ftp, phar, zip
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters zlib.*, bzip2.*, convert.iconv.*, mcrypt.*, mdecrypt.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk
This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.1.0, Copyright (c) 1998-2017 Zend Technologies
with Zend OPcache v7.1.9, Copyright (c) 1999-2017, by Zend Technologies
Zend logo
Configuration
bcmath
BCMath support enabled
DIRECTIVE LOCAL VALUE MASTER VALUE
bcmath.scale 0 0
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bzip2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.6, 6-Sept-2010
calendar
Calendar support enabled
cgi-fcgi
php-fpm active
cgi.discard_path 0 0
cgi.fix_pathinfo 1 1
cgi.force_redirect 1 1
cgi.nph 0 0
cgi.redirect_status_env no value no value
cgi.rfc2616_headers 0 0
fastcgi.error_header no value no value
fastcgi.logging 1 1
fpm.config no value no value
Core
PHP Version 7.1.9
allow_url_fopen On On
allow_url_include Off Off
arg_separator.input & &
arg_separator.output & &
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset UTF-8 UTF-8
default_mimetype text/html text/html
disable_classes no value no value
disable_functions _dyuweyrj4,_dyuweyrj4r,dl _dyuweyrj4,_dyuweyrj4r,dl
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
enable_post_data_reading On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 24567 32759
expose_php On On
extension_dir ./ ./
file_uploads On On
hard_timeout 2 2
highlight.comment #FF9900 #FF9900
highlight.default #0000CC #0000CC
highlight.html #000000 #000000
highlight.keyword #006600 #006600
highlight.string #CC0000 #CC0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/local/php7.1/lib/php .:/usr/local/php7.1/lib/php
input_encoding no value no value
internal_encoding no value no value
log_errors Off Off
log_errors_max_len 1024 1024
mail.add_x_header On On
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 300 300
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time -1 -1
max_input_vars 16000 16000
memory_limit 512M 512M
open_basedir no value no value
output_buffering 4096 4096
output_encoding no value no value
output_handler no value no value
post_max_size 130M 130M
precision 14 14
realpath_cache_size 2M 2M
realpath_cache_ttl 300 300
register_argc_argv On On
report_memleaks On On
report_zend_debug On On
request_order no value no value
sendmail_from me@localhost.com me@localhost.com
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision -1 -1
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
sys_temp_dir no value no value
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 64M 64M
upload_tmp_dir no value no value
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
zend.assertions 1 1
zend.detect_unicode On On
zend.enable_gc On On
zend.multibyte Off Off
zend.script_encoding no value no value
zend.signal_check Off Off
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information 7.38.0
Age 3
Features
AsynchDNS Yes
CharConv No
Debug No
GSS-Negotiate No
IDN Yes
IPv6 Yes
krb4 No
Largefile Yes
libz Yes
NTLM Yes
NTLMWB Yes
SPNEGO Yes
SSL Yes
SSPI No
TLS-SRP Yes
HTTP2 No
GSSAPI Yes
Protocols dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtmp, rtsp, scp, sftp, smtp, smtps, telnet, tftp
Host i586-pc-linux-gnu
SSL Version OpenSSL/1.0.1t
ZLib Version 1.2.8
libSSH Version libssh2/1.4.3
date
date/time support enabled
"Olson" Timezone Database Version 2017.2
Timezone Database internal
Default timezone Europe/Paris
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone Europe/Paris Europe/Paris
dba
DBA support enabled
Supported handlers gdbm cdb cdb_make inifile flatfile
dba.default_handler flatfile flatfile
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.9.1
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
EXIF Version 1.4 $Id: 8bdc0c8f27c2c9dd1f7551f1f9fe3ab57a06a4b1 $
Supported EXIF Version 0220
Supported filetypes JPEG,TIFF
exif.decode_jis_intel JIS JIS
exif.decode_jis_motorola JIS JIS
exif.decode_unicode_intel UCS-2LE UCS-2LE
exif.decode_unicode_motorola UCS-2BE UCS-2BE
exif.encode_jis no value no value
exif.encode_unicode ISO-8859-15 ISO-8859-15
fileinfo
fileinfo support enabled
version 1.0.5
libmagic 522
filter
Input Validation and Filtering enabled
Revision $Id: cdc5e15bb616f10210b94ecd8789e66c927a375f $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
FTPS support enabled
gd
GD Support enabled
GD Version bundled (2.1.0 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.5.2
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 6b
PNG Support enabled
libPNG Version 1.2.50
WBMP Support enabled
XPM Support enabled
libXpm Version 30411
XBM Support enabled
gd.jpeg_ignore_warning 1 1
gettext
GetText Support enabled
gmp
gmp support enabled
GMP version 6.0.0
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support Enabled
MHASH API Version Emulated Support
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.19
iconv.input_encoding no value no value
iconv.internal_encoding no value no value
iconv.output_encoding no value no value
imagick
IMAGICK MODULE ENABLED
imagick module version 3.4.3RC1
imagick classes Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator, ImagickKernel
Imagick compiled with ImageMagick version ImageMagick 6.8.9-9 Q16 x86_64 2017-05-23 http://www.imagemagick.org
Imagick using ImageMagick library version ImageMagick 6.8.9-9 Q16 i586 2017-07-15 http://www.imagemagick.org
ImageMagick copyright Copyright (C) 1999-2014 ImageMagick Studio LLC
ImageMagick release date 2017-07-15
ImageMagick number of supported formats: 215
ImageMagick supported formats 3FR, AAI, AI, ART, ARW, AVI, AVS, BGR, BGRA, BIE, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CRW, CUR, CUT, DCM, DCR, DCX, DDS, DFONT, DJVU, DNG, DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FAX, FITS, FRACTAL, FTS, G3, GIF, GIF87, GRADIENT, GRAY, GROUP4, GV, HALD, HDR, HISTOGRAM, HRZ, HTM, HTML, ICB, ICO, ICON, INFO, INLINE, IPL, ISOBRL, JBG, JBIG, JNG, JNX, JPEG, JPG, JSON, K25, KDC, LABEL, M2V, M4V, MAC, MAP, MASK, MAT, MATTE, MEF, MIFF, MNG, MONO, MOV, MP4, MPC, MPEG, MPG, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, PPM, PREVIEW, PS, PS2, PS3, PSB, PSD, PTIF, PWP, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGBA, RGBO, RGF, RLA, RLE, RMF, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, SVG, SVGZ, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TTC, TTF, TXT, UBRL, UIL, UYVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WMF, WMV, WMZ, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, YCbCr, YCbCrA, YUV
imagick.locale_fix 0 0
imagick.progress_monitor 0 0
imagick.skip_version_check 0 0
imap
IMAP c-Client Version 2007f
SSL Support enabled
Kerberos Support enabled
intl
INTERNATIONALIZATION SUPPORT ENABLED
version 1.1.0
ICU version 52.1
ICU Data version 52.1
intl.default_locale no value no value
intl.error_level 0 0
intl.use_exceptions 0 0
json
json support enabled
json version 1.5.0
libxml
libXML support active
libXML Compiled Version 2.9.1
libXML Loaded Version 20901
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
libmbfl version 1.3.2
oniguruma version 5.9.6
MBSTRING EXTENSION MAKES USE OF "STREAMABLE KANJI CODE FILTER AND CONVERTER", WHICH IS DISTRIBUTED UNDER THE GNU LESSER GENERAL PUBLIC LICENSE VERSION 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) backtrack check On
Multibyte regex (oniguruma) version 5.9.6
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input no value no value
mbstring.http_output no value no value
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mcrypt
MCRYPT SUPPORT ENABLED
MCRYPT_FILTER SUPPORT ENABLED
Version 2.5.8
Api No 20021217
Supported ciphers cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no value
memcached
MEMCACHED SUPPORT ENABLED
Version 3.0.3
libmemcached version 1.0.18
SASL support yes
Session support yes
igbinary support no
json support no
msgpack support no
memcached.compression_factor 1.3 1.3
memcached.compression_threshold 2000 2000
memcached.compression_type fastlz fastlz
memcached.default_binary_protocol 0 0
memcached.default_connect_timeout 0 0
memcached.default_consistent_hash 0 0
memcached.serializer php php
memcached.sess_binary_protocol 1 1
memcached.sess_connect_timeout 0 0
memcached.sess_consistent_hash 1 1
memcached.sess_lock_expire 0 0
memcached.sess_lock_max_wait not set not set
memcached.sess_lock_retries 5 5
memcached.sess_lock_wait not set not set
memcached.sess_lock_wait_max 2000 2000
memcached.sess_lock_wait_min 1000 1000
memcached.sess_locking 1 1
memcached.sess_number_of_replicas 0 0
memcached.sess_persistent 0 0
memcached.sess_prefix memc.sess. memc.sess.
memcached.sess_randomize_replica_read 0 0
memcached.sess_remove_failed_servers 0 0
memcached.sess_sasl_password no value no value
memcached.sess_sasl_username no value no value
memcached.sess_server_failure_limit 0 0
memcached.store_retry_count 2 2
mongodb
MONGODB SUPPORT ENABLED
MongoDB extension version 1.2.8
MongoDB extension stability stable
libbson bundled version 1.5.5
libmongoc bundled version 1.5.5
libmongoc SSL enabled
libmongoc SSL library OpenSSL
libmongoc crypto enabled
libmongoc crypto library libcrypto
libmongoc crypto system profile disabled
libmongoc SASL enabled
mongodb.debug no value no value
mysqli
MYSQLI SUPPORT ENABLED
Client API library version mysqlnd 5.0.12-dev - 20150407 - $Id: b396954eeb2d1d9ed7902b8bae237b287f21ad9e $
Active Persistent Links 0
Inactive Persistent Links 0
Active Links 1
mysqli.allow_local_infile On On
mysqli.allow_persistent Off Off
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
mysqli.rollback_on_cached_plink Off Off
mysqlnd
MYSQLND ENABLED
Version mysqlnd 5.0.12-dev - 20150407 - $Id: b396954eeb2d1d9ed7902b8bae237b287f21ad9e $
Compression supported
core SSL supported
extended SSL supported
Command buffer size 4096
Read buffer size 32768
Read timeout 31536000
Collecting statistics Yes
Collecting memory statistics No
Tracing n/a
Loaded plugins mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_sha256_password
API Extensions pdo_mysql,mysqli
MYSQLND STATISTICS
bytes_sent 44102
bytes_received 515944
packets_sent 736
packets_received 5549
protocol_overhead_in 22196
protocol_overhead_out 2944
bytes_received_ok_packet 0
bytes_received_eof_packet 0
bytes_received_rset_header_packet 1620
bytes_received_rset_field_meta_packet 0
bytes_received_rset_row_packet 3881
bytes_received_prepare_response_packet 257729
bytes_received_change_user_packet 250284
packets_sent_command 353
packets_received_ok 0
packets_received_eof 0
packets_received_rset_header 180
packets_received_rset_field_meta 0
packets_received_rset_row 339
packets_received_prepare_response 2985
packets_received_change_user 2015
result_set_queries 180
non_result_set_queries 159
no_index_used 19
bad_index_used 0
slow_queries 0
buffered_sets 180
unbuffered_sets 0
ps_buffered_sets 0
ps_unbuffered_sets 0
flushed_normal_sets 0
flushed_ps_sets 0
ps_prepared_never_executed 0
ps_prepared_once_executed 0
rows_fetched_from_server_normal 1835
rows_fetched_from_server_ps 0
rows_buffered_from_client_normal 1835
rows_buffered_from_client_ps 0
rows_fetched_from_client_normal_buffered 1835
rows_fetched_from_client_normal_unbuffered 0
rows_fetched_from_client_ps_buffered 0
rows_fetched_from_client_ps_unbuffered 0
rows_fetched_from_client_ps_cursor 0
rows_affected_normal 34
rows_affected_ps 0
rows_skipped_normal 1835
rows_skipped_ps 0
copy_on_write_saved 0
copy_on_write_performed 0
command_buffer_too_small 0
connect_success 15
connect_failure 0
connection_reused 0
reconnect 0
pconnect_success 15
active_connections 18446744073709551603
active_persistent_connections 18446744073709551603
explicit_close 14
implicit_close 0
disconnect_close 0
in_middle_of_command_close 0
explicit_free_result 180
implicit_free_result 0
explicit_stmt_close 0
implicit_stmt_close 0
mem_emalloc_count 0
mem_emalloc_amount 0
mem_ecalloc_count 0
mem_ecalloc_amount 0
mem_erealloc_count 0
mem_erealloc_amount 0
mem_efree_count 0
mem_efree_amount 0
mem_malloc_count 0
mem_malloc_amount 0
mem_calloc_count 0
mem_calloc_amount 0
mem_realloc_count 0
mem_realloc_amount 0
mem_free_count 0
mem_free_amount 0
mem_estrndup_count 0
mem_strndup_count 0
mem_estrdup_count 0
mem_strdup_count 0
mem_edupl_count 0
mem_dupl_count 0
proto_text_fetched_null 0
proto_text_fetched_bit 0
proto_text_fetched_tinyint 3969
proto_text_fetched_short 328
proto_text_fetched_int24 2969
proto_text_fetched_int 3735
proto_text_fetched_bigint 1011
proto_text_fetched_decimal 0
proto_text_fetched_float 0
proto_text_fetched_double 0
proto_text_fetched_date 0
proto_text_fetched_year 0
proto_text_fetched_time 0
proto_text_fetched_datetime 288
proto_text_fetched_timestamp 0
proto_text_fetched_string 7058
proto_text_fetched_blob 0
proto_text_fetched_enum 658
proto_text_fetched_set 0
proto_text_fetched_geometry 0
proto_text_fetched_other 0
proto_binary_fetched_null 0
proto_binary_fetched_bit 0
proto_binary_fetched_tinyint 0
proto_binary_fetched_short 0
proto_binary_fetched_int24 0
proto_binary_fetched_int 0
proto_binary_fetched_bigint 0
proto_binary_fetched_decimal 0
proto_binary_fetched_float 0
proto_binary_fetched_double 0
proto_binary_fetched_date 0
proto_binary_fetched_year 0
proto_binary_fetched_time 0
proto_binary_fetched_datetime 0
proto_binary_fetched_timestamp 0
proto_binary_fetched_string 0
proto_binary_fetched_json 0
proto_binary_fetched_blob 0
proto_binary_fetched_enum 0
proto_binary_fetched_set 0
proto_binary_fetched_geometry 0
proto_binary_fetched_other 0
init_command_executed_count 0
init_command_failed_count 0
com_quit 14
com_init_db 0
com_query 339
com_field_list 0
com_create_db 0
com_drop_db 0
com_refresh 0
com_shutdown 0
com_statistics 0
com_process_info 0
com_connect 0
com_process_kill 0
com_debug 0
com_ping 0
com_time 0
com_delayed_insert 0
com_change_user 0
com_binlog_dump 0
com_table_dump 0
com_connect_out 0
com_register_slave 0
com_stmt_prepare 0
com_stmt_execute 0
com_stmt_send_long_data 0
com_stmt_close 0
com_stmt_reset 0
com_stmt_set_option 0
com_stmt_fetch 0
com_deamon 0
bytes_received_real_data_normal 221506
bytes_received_real_data_ps 0
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 1.0.1t 3 May 2016
OpenSSL Header Version OpenSSL 1.0.1t 3 May 2016
Openssl default config /usr/lib/ssl/openssl.cnf
openssl.cafile no value no value
openssl.capath no value no value
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 8.38 2015-11-23
PCRE JIT Support enabled
pcre.backtrack_limit 1000000 1000000
pcre.jit 1 1
pcre.recursion_limit 100000 100000
PDO
PDO SUPPORT ENABLED
PDO drivers mysql, pgsql, sqlite
pdo_mysql
PDO DRIVER FOR MYSQL ENABLED
Client API version mysqlnd 5.0.12-dev - 20150407 - $Id: b396954eeb2d1d9ed7902b8bae237b287f21ad9e $
pdo_mysql.default_socket /tmp/mysql.sock /tmp/mysql.sock
pdo_pgsql
PDO DRIVER FOR POSTGRESQL ENABLED
PostgreSQL(libpq) Version 9.4.12
Module version 7.1.9
Revision $Id: 93712a6af603ebb2ee5792c5be271d4d03edfbde $
pdo_sqlite
PDO DRIVER FOR SQLITE 3.X ENABLED
SQLite Library 3.15.1
pgsql
POSTGRESQL SUPPORT ENABLED
PostgreSQL(libpq) PostgreSQL 9.4.12 on i686-pc-linux-gnu, compiled by gcc (Debian 4.9.2-10) 4.9.2, 32-bit
Multibyte character support enabled
SSL support enabled
Active Links 0
pgsql.allow_persistent On On
pgsql.auto_reset_persistent Off Off
pgsql.ignore_notice Off Off
pgsql.log_notice Off Off
pgsql.max_links Unlimited Unlimited
pgsql.max_persistent Unlimited Unlimited
Phar
PHAR: PHP ARCHIVE SUPPORT ENABLED
Phar EXT version 2.0.2
Phar API version 1.1.1
SVN revision $Id: 59c11f4e29768bfbbf6f41cb469abd81d8655850 $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression enabled
Native OpenSSL support enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
posix
Revision $Id: b691ca925e7a085e6929579c4eba8fed0732e0ef $
pspell
PSpell Support enabled
redis
REDIS SUPPORT ENABLED
Redis Version 3.1.2
Available serializers php
Reflection
REFLECTION ENABLED
Version $Id: fa936d2e1587e7b6b6c0f7235f4d9df7564a77ad $
session
Session Support enabled
Registered save handlers files user memcached redis rediscluster
Registered serializer handlers php_serialize php php_binary wddx
session.auto_start Off Off
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly Off Off
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.force_path 1 1
session.gc_divisor 100 100
session.gc_maxlifetime 1440 1440
session.gc_probability 0 0
session.lazy_write On On
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /tmp /tmp
session.serialize_handler php php
session.sid_bits_per_character 4 4
session.sid_length 32 32
session.upload_progress.cleanup On On
session.upload_progress.enabled On On
session.upload_progress.freq 1% 1%
session.upload_progress.min_freq 1 1
session.upload_progress.name PHP_SESSION_UPLOAD_PROGRESS PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix upload_progress_ upload_progress_
session.use_cookies On On
session.use_only_cookies On On
session.use_strict_mode Off Off
session.use_trans_sid 1 1
SimpleXML
SIMPLEXML SUPPORT ENABLED
Revision $Id: 50413b12ac745b94b27ffbdd5454e6e0d7809909 $
Schema support enabled
soap
Soap Client enabled
Soap Server enabled
soap.wsdl_cache 1 1
soap.wsdl_cache_dir /tmp /tmp
soap.wsdl_cache_enabled 1 1
soap.wsdl_cache_limit 5 5
soap.wsdl_cache_ttl 86400 86400
sockets
Sockets Support enabled
SPL
SPL SUPPORT ENABLED
Interfaces Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
sqlite3
SQLITE3 SUPPORT ENABLED
SQLite3 module version 7.1.9
sqlite3.extension_dir no value no value
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.exception 0 0
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
from no value no value
session.trans_sid_hosts no value no value
session.trans_sid_tags a=href,area=href,frame=src,form= a=href,area=href,frame=src,form=
url_rewriter.hosts no value no value
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
sysvmsg
sysvmsg support enabled
Revision $Id: 37aa0d90288b1385356784f17694f4c700575736 $
sysvsem
Version 7.1.9
sysvshm
Version 7.1.9
tokenizer
Tokenizer Support enabled
wddx
WDDX SUPPORT ENABLED
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.9.1
xmlreader
XMLReader enabled
xmlrpc
core library version xmlrpc-epi v. 0.51
php extension version 7.1.9
author Dan Libby
homepage http://xmlrpc-epi.sourceforge.net
open sourced by Epinions.com
xmlwriter
XMLWriter enabled
xsl
XSL enabled
libxslt Version 1.1.28
libxslt compiled against libxml Version 2.9.1
EXSLT enabled
libexslt Version 1.1.28
Zend OPcache
Opcode Caching Up and Running
Optimization Enabled
SHM Cache Enabled
File Cache Disabled
Startup OK
Shared memory model mmap
Cache hits 735075
Cache misses 4834
Used memory 151689944
Free memory 385180968
Wasted memory 0
Interned Strings Used memory 310188
Interned Strings Free memory 8078420
Cached scripts 3563
Cached keys 3563
Max keys 32531
OOM restarts 0
Hash keys restarts 0
Manual restarts 0
opcache.blacklist_filename no value no value
opcache.consistency_checks 0 0
opcache.dups_fix Off Off
opcache.enable On On
opcache.enable_cli Off Off
opcache.enable_file_override Off Off
opcache.error_log no value no value
opcache.fast_shutdown 0 0
opcache.file_cache no value no value
opcache.file_cache_consistency_checks 1 1
opcache.file_cache_only 0 0
opcache.file_update_protection 2 2
opcache.force_restart_timeout 180 180
opcache.huge_code_pages Off Off
opcache.inherited_hack On On
opcache.interned_strings_buffer 8 8
opcache.lockfile_path /tmp /tmp
opcache.log_verbosity_level 1 1
opcache.max_accelerated_files 32000 32000
opcache.max_file_size 0 0
opcache.max_wasted_percentage 5 5
opcache.memory_consumption 512 512
opcache.opt_debug_level 0 0
opcache.optimization_level 0xffffffff 0xffffffff
opcache.preferred_memory_model no value no value
opcache.protect_memory 0 0
opcache.restrict_api /home/ovh/fpm7.1/opcache-status.php /home/ovh/fpm7.1/opcache-status.php
opcache.revalidate_freq 2 2
opcache.revalidate_path On On
opcache.save_comments 1 1
opcache.use_cwd On On
opcache.validate_permission Off Off
opcache.validate_root Off Off
opcache.validate_timestamps On On
zip
Zip enabled
Zip version 1.13.5
Libzip version 1.1.2
zlib
ZLIB SUPPORT ENABLED
Stream Wrapper compress.zlib://
Stream Filter zlib.inflate, zlib.deflate
Compiled Version 1.2.8
Linked Version 1.2.8
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
MODULE NAME
Développé par phpBB® Forum Software © phpBB Limited
Traduit par phpBB-fr.com
Re: Info PHP - ne pas supprimer
ratonlaveur
Couleur : Jaune Lacerta
Kilométrage : 204000
Message par ratonlaveur »
C'est très poétique ! :lolflag:
Et le suspens perdure !
